8ob
- Nescient in the vale
Needed a powerful portable lightweight winch that could run all day for weeks on end pulling willow out of a lake and onto an island complete with roots, nothing out out there readily available with the kind of grunt needed for less than 2k , we built a frame, mounted a S/H capstan landy winch and powered it with a new Loncin 6.5hp four stroke engine thats got a 2/1 reduction box on it. I used all the landy shafts which I cut down and machined up a drive hub for the ball drive which normally goes on the landy crank.
Mock up in the chassis
Shortened the Landy driveshaft
Spun up a hub on the lathe and milled in the drive slots
Vid of the rest of the brackets and gizmos with it staked to the ground doing its stuff. Its on its third day of graft now
Clock the cut down cv boot on the driveshaft, its grease filled.
you get better control with a capstan compared to drum winches.
