SilverSaloon
hi
on my migmate 150 turbo (gassless) i am getting through tips at an astonishing rate.... they seem to get clogged and the wire cannot get through them well. i'm using 0.8mm gasless wire.
if i fit a new one, after about an inch of welding the wire stops getting through and i need to take the tip off, clean it up and refit. then it may or may not continue to work for a bit.... often i need to just fit a new tip.
any ideas - is this normal (i'm new to welding)
i know tips are cheap at around £3 for a set of 3 or something but is this normal?
thanks
derek
thanks
derek
can't even get my head around how you managed that, MK!
