Hello all,
I have no experience of welding other than a couple of occasions in earlier years when someone has offered me to 'have a go' at they're arc welding kit which was always a total failure. Would anyone mind giving me some advice on how to get started and on problems I now find... real basic questions and probably silly (apologies).
I'm trying to learn arc welding so as to repair a motorcycle frame after giving it to two different 'pro' welders who have done less than a good job. I'm not doing anything structural or strength critical, I'm more trying to cover/tidy up what has already been done (can't afford to risk someone else messing it up more).
Please excuse me if I get any terminology wrong, I really am a dummy to this!
I have purchased a Cevik 160 Amp A/C machine and a supply of Rutile rods to practise with (1.6mm and 2.6mm). I would have liked to have purchased an inverter machine, but I just couldn't afford the cost and I thought if I could master the AC it would give me a good basic grounding to start from.
As I say, please forgive me, these are real basic/silly questions:
1. is new sheet metal the best to practise on?. I ensure the metal is clean and rust free and have had some success in running beads, but it seems to sometimes be a difficult material (compared to some other scraps I have tried) to stick the arc on... dozens of little 'dots' where I keep tapping/scratching to unsuccessfully get an arc. I'm trying mostly with the 2.6 rods with settings between 80-120A.
2. Really silly question... how much should I be able to see through the visor?. I have a cheap helmet and a hand held visor (the hand held I seem to get on best with) with #11 & #12 lenses. I can see the molten metal and obviously the arc flashing, but I can't for the life of me see where I intend to go. Is this normal or should I consider a weaker lens and if so how low can I go without risking eye damage.
3. From what I read on the net, I think I understand that the arc length is measured in mm. Is it me or my machine because this sounds like a super human feat to keep the rod off the material to such a degree and I am finding (I think what is happening) that I have to have to have the rod lightly dragging on the material because I don't get an arc if I raise the rod very far. How far could an arc actually be expected to jump with my setup?
I have searched to internet an forum, but I'm finding it difficult to pick out what actually applies to me, so any advice would be really appreciated.
Sorry for the long post, I tried to be accurate as far as my knowledge takes me.
Thank you very much.
Jorge
Jorge
I tend to avoid fumes, but I hadn't realised this. I usually get these symptoms after a beer or two and would never have known it was my welding!
