Ive got a little plumbing job to do , the farm is on low pressure water supply .i need to boost up the pressure for a machine im instaling in the milking parlour . it only needs a small volume of water (the outlet is only about 6mm bore tubing ) Anyway ive bought a small on demand diaphram pump the sort of thing you would use on a boat or in a caravan , obviously i need a transformer and bridge rectifier but my question what size of transformer
The pump motor pulls 4 amp max it says with a 10 amp slow blow fuse .
so 230 volt to 12 volt but anyone know what rating ??VA oh and any good online supplier . i had a browse on maplins site but i couldnt see anything suitable
cheers guys
cheers guys
