Let it go to my head!what are you going to do with all that power ?
seriously ?Let it go to my head!
Is there any way to use a cheap remote-controlled relay on the transformer input so it would be off when you do not need it, but remotely-power-uppable when you do?
a site transformer for multiple useseriously ?
What would someone in the UK need 90 amps of 120 vac for ?
Might want a snubberThat's what I've done.
I have switched sockets that are supposed to turn the plug live when switched on (sockets are always live)
I rewired the sockets with a 12v supply to operate a relay when a socket is switched on.
Works well but all sockets are live when one is switched so probably not as safe, but works for me.
You need to have a plug inserted before you can turn the power on (or off) or in my case energinise the transformer.
I also have an illuminated switch at the door that powers the system so I don't forget to turn it off on the way out and the transformer isn't left live when I'm not using 110v.
Only minor issue is there is a fair arc every time I turn the power off, but it hasn't fried the relay yet.
I think I have it on a C type breaker but it only trips the very odd time when switched on, during the very coldest weather.
It might have been for a spot welder.seriously ?
not worth doing there filled with a resin mixJust get another handheld TX and weigh that big one in £££
I've seen UK single phase spot welders they run on 240 vac.It might have been for a spot welder.
