Hi I have a weird problem with a turbo130, it feeds wire along to the torch fine, and if I loosely fit the contact tip it still feeds fine, but when I tighten the tip the feed becomes very slow and erratic. Feels like something is being pinched, but what?
Second, does it matter which way round the springy steel liner goes in the torch neck? It doesn't affect the feeding problem either way.
And finally, since I'm not very familiar with this machine, should the tension screw on the drive roller have to be screwed right down? I usually use a SIP handymig and it doesn't seem to need as much pressure.
Sorry to be such a numpty!
