marknotgeorge
Doing sums for a living since 2009.
I've nearly finished the left floorpan of my TR7, and I'm now thinking about coating it. I've completed the front half, and so far I've Kurusted the bare metal inside the car (I previously wire-brushed the original floorpan - the repair panel came in red oxide), before a couple of coats of U-Pol Acid #8 and a couple of coats of primer, which seems to have worked well.
I plan to do similar to the rear half and the underside, before seam-sealing using Tiger Seal or Sikaflex and top-coating. For the underside, I plan to top coat with U-Pol Gravitex stonechip. I've seen good reports of this on t'interweb. I plan to brush it on, not having a compressor. I've also heard it has sound deadening properties, so I'm thinking of using it inside.
Any thoughts?
Any thoughts?
