Hello,
My name is Pad, new here, hello! I am currently undertaking a full restoration of a 69 Bay window camper. As with many of these things, it started off as just a basic repaint, but have now progressed to a full strip and proper job... the bus has been imported from Texas so is unbelievably solid so seems a shame not to go the full hog on it.
Anyway, I am currently tackling the underneath and have stripped all suspension etc off so it is just the shell underneath. Everything is super solid but over the years in the Texan desert it has accumulated a sort of 'rust dust' surface. I have started rubbing down with scotchbrite but this is extremely tiresome and I cant get into all the nooks and crannies.
First question, I assume that I cant just paint over this surface as even though its just a dusting, it will cause problems later?
If so, what is the best way to prep? I could invest in a sand blasting equipment if necessary... if that is the best way to go then what would be best to hook up to my Hydrovane 15 (3hp 150PSi)?
And finally, once prepped, what would be the best primer/coating to apply? I want it to be protected well for the future..
A couple of photos so you can see what I am talking about
Thanks in advance for any advice!
Pad
Pad
