rockweasel
- none
Until now I have managed to stick together my projects using flat or horizontal welds. My latest project means I'm going to have to have a go at some vertical welds - and the practice sessions are not going well so far.
I'm using an arc welder and practicing using 2.5mm and 3.2mm 6013 rods as that is what I have to hand. I'm "just" trying to run some beads up a vertical plate (about 4mm thick.) No matter what setting I put the amperage at (within the suggested range for the rod), I get blobs of weld as the molten pool gets pulled down by gravity.
As I understand it, a 6011 rod is fast freeze and maybe a bit easier to use in a vertical weld, but as I don't have any to hand and 6013 is meant to be used in any position, I thought I'd have a go using that.
What am I doing wrong? Rod/Amps/Speed/Angle/Distance?
Is a vertical weld going to be strong and have sufficient penetration given that the amperage is so low?
Thanks!
Thanks!
