rtcosic
- Warwickshire
Finally wired up the VFD on my 370W drill motor.
All works - speeds up, slows down, stops, starts and runs backwards.
The motor is a 1425 rpm Hawker Siddeley Brook Crompton Parkinson motor to BS3000/11 according to the data plate. It is huge compared to the 370W single phase motor on the cheap DIY shed pillar drill.
I have replaced the bearings with new SKF ones rated for 19'000 rpm.
I have the speed range set from 5 to 75 Hz or 143 - 2140 rpm. The motor sounds quite happy at those speeds.
What is the maximum rpm I should try?
The drill data plate has the highest quill speed over 4000 rpm which I don't plan to exceed.
