normspanners
I have a large compressor pump that I am going to drive off single phase I have a large 1ph motor off a large ind steamer/power wash not sure of the kw cause I cant see the plate but I would guess 2.5 ish .
Obviously the gearing will have to worked out, as I want the pump to run fairly slowly to keep the noise down.
I also have a large 4-5 kw 3ph motor and an inverter speed controller.
I was thinking of running the compressor unloaded up to speed before the load cuts in, and to do the main filling with the pump on two cylinders, then swap the pump onto one cylinder at a predetermined current load, to do the final high pressure pumping , to get it to 11 bar ish, without incurring high hp pumping current.
My question is, what is best a 3ph on an inverter, ramped to save on massive inrush or a large 1ph dol as such.
What would be the most efficient method ? are the inverters quite effiecient /cost effective for long term use.
