What is a self priming pump?
Do I need one or can I go with one that is non self priming?
I tend to do things with scrap stuff
I have just been playing with a central heating pump, to use as a coolant pump.
I have decided to alter the pump so the pump it self is in the water tank[i.e make it look like a normal coolant pump].
My Tig has a watercooled torch and it runs all the time, only downside is the pump is noisy. I have had it 20 years and keep meaning to pull the pump out of the tank and see why it's so noisy. but not yet got round to it.
A Holley fuel pump[probably plenty of other pumps like them] would work as a pump, it's a vane pump and can be mounted above the reservoir, I use them for coolant and parts washer.
The Holley is rather expensive![]()
.... In my opinion the bigger the bodge the better....
Central heating pumps need a head of water to work well, Pond pumps although pump a lot of water as soon as there is a restriction they won't pump, and there in lies the problem. You need to spend money to get a pump that will pump at pressure
