MysterG
- Wiltshire, UK
Been planning a water feature in an area of our garden for ages and even had the container sitting waiting for over a year. Then one trip to a garden centre and my Wife spies some big planters she really likes the look of and I glibly suggest that maybe we could use them as the basis of the feature … I should learn to keep quiet.
Basically it will be one large pot (approx. 2ft high and across) sat on a plinth acting as reservoir and containing the pump. Smaller pot supported somehow above this into which the water is pumped and bubbles over and down into the lower pot.
I should also mention pots are proper heavy glazed stuff so not light.
So basically I have to make a 'stand' to support the higher pot.
Enter stage right an old (50yrs +) washing line post rusty as heck but still solid with 3-4mm wall, around the top four lengths of 5mm flat with their ends turned up. This allows the top pot to sit, further support will come from some decoration later on.
The use of this big hollow section will allow me to run the water pipe up inside it to the top pot.
Decided I wanted to do something organic for the decoration, fancied flowers or leaves/vines ..
The only stuff I have for cutting sheet is a variety of tin snips and aviation shears, and a jig saw.
For the metal I was planning to use (old rusted sheet I've had for years) the hand shears are heavy going and the jigsaw I find works better on thicker stuff.
Plasma cutter would be nice except for the cost of buying, and the potential upgrade to my compressor and garage wiring … after a bit of research I thought I would try one of these electric shears.
https://www.amazon.co.uk/gp/product/B008CNF278/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Worst case it would come in handy for cutting sheet for car repairs.
Have to say I am very impressed. Using a paper template to draw an outline on the sheet, I could cut reasonably accurately (okay a few dabs of weld might be needed for the odd 'over snip') and I got better with it as I went on.
After a couple of hours cutting, filing and bashing I have these. Probably take another day to get enough for the look I'm after, or I may change my plans if I get fed up with making them. Just need to produce a couple of extra templates of different sizes.
I'm hoping to just have it rust then lacquer it all. The water feature will have to be drained every winter so I'm not adverse to a yearly recoat.
More updates as progress unfolds ...
