foy9999
- East Kilbride
Hi there.
I'm fitting a mixer-tap where there used to be 2 separate taps and had to turn off the hot and cold to do this as there are no isolation valves in the pipework.
house is split-level. Boiler is not combi.
Turned the stopcock off in kitchen and cold in kitchen stopped running but no chance to the cold (or hot) in room I'm working on which in in lower lever.
A friendly kitchen-fitter came went up loft, said he closed off 5 things (don't know if they were gate-valves or stopcocks) and bot the hot and cold in lower-level now 'off'
However there was still enough water coming out the pipes to get the floor pretty wet so I put the old tap unit back on the pipes to keep things dry as the floor-fitter wanted to get the laminate down.
When he was done I could still fill a couple of cans with water from the tap before the dribble turned into a very small dribble.
I could then quickly cut the pipes and put isolation-valves on but still too much water for my liking and it all needs to be disturbed again tomorrow when the worktop etc is offered up.
Is it the case that gate-valves don't completely shut off the supply from tank?
Saw a video on YouTube where the guy said stopcocks do but water will get past gate-valves.
Or has the guy just not closed them tightly enough?
Or is this just water in the pipes coming down under its own pressure (gravity)?
