steviec_lj
Rust Welding Professional
- Barnetby, N.Lincs
Hi guys,
On with the installation and use of Oxy/Propane again, this time the cylinders are going to be stored in a secure area in the corner of the unit.
Problem I have at the moment is, that the inlet and outlet connections on the Wescol Regulator I have for the Propane is the wrong way around, and a mighty pain in the rear! It would mean moving an entire run of racking around 18mtrs in length, by 200mm so the current set up could be used.
I don't fancy emptying the racking and I highly doubt pulling it with a Scania R310 will prove that it can be moved fully loaded, although it would be fun to try.
So... Answers on a postcard
