on the dial marker 1-7 with 0 being off i take it that 1 is the lowest setting and 7 the highest. I am trying to weld body work but keep blowing holes. Any idea Chaps??
The lowest setting may not be low enough for the material you are welding, especially when some machines have 40amps or even higher as their bottom range.
Even at the most common 30 amps that a lot of hobby machines tend to have, you may have to do the thin metal technique demonstrated in the forums tutorial.
