Right..........
I am now miffed and tired of swearing, restarting on even the smallest jobs
This is my truck build thread where the welder is being used (well, will be used)
http://67-72chevytrucks.com/vboard/showthread.php?t=585901
My Clarke welder, pictured below does a decent enough home hobby weld and even heavy stuff, but the torch started to fall apart, front tip ahead of trigger falling out/off longer ago than should be tolerated.
I am about to start welding the sheet metal on the truck, and cannot work like this.
So my question is this.......
What is a Euro Torch?
Is it easily compatible with my welder, in other words, can an idiot like me fit it without having to call a helpline?
Or do I replace it with the clearly inferior original torch?
ALSO...... As I have not opened it to look, can one upgrade the earth cable easily? The one fitted is very skinny. I did upgrade the clamp before as the pressed steel one was *****.
All advice appreciated.
Thanks for the advice.
Torch
Welder
Torch
Welder
