So I was dabbling with welding some metal pipe (2mm mild steel wall) onto a flat base, like so:
I'm more concerned with it being leak proof at present, rather than being structurally strong, however what are the best ways to achieve this with MIG?
Whilst welding this, I ground back the "starts" of the welds, as I'm guessing adhesion/fusion will not be as strong there as further into the weld when things have heated up, and then covered them again (starting a bit further away, obviously).
Always looking to learn new things, so are there any other dos and don'ts?
I have a slight bit of undercut on the plate, but it doesn't really worry me, as it's not a structural item. I'm guessing taking the amps down a notch and/or turning down the wire speed would fix this.
The above was done using my clarke 135te welder.
Some more weld pics and the half way finished article (modified from a previous incarnation):
