Amps is wirespeed with Mig welding. Not just my mig a portamig a clarke, anyones. On Inverter based syngeric migs it is possible to view the amperage and adjust it up or down (the machine will calculate the necessary wirespeed to achieve the proposed amps. But with Transformers you set your wirespeed first and then you see how many amps that relates too when you start welding.
What do you mean 'to top it all off'? Have you had some sort of negative experience or do you regret your purchase?
Your supposed to marry the wire speed/voltage relationship on the lowest voltage step and then it should be there or there about's on all of the higher settings.
Regarding the 12 steps on manual mode, that is perfectly adequate for a 250 amp out put machine. Some of them only come with 6 or 8 steps.
No, you would just have a higher wire speed for the same current as the 0.8mm wire. If its a 125 amp machine, you will only get 125 amps out of it regardless of the wire diameter.
No what I mean is that with mig welding in general, you can't increase the amps without increasing the wire speed.
However, by increasing the wirespeed, you then need more voltage to 'burn' that wire off.
So if you increase the wirespeed too much without going to the next voltage step, you will end up with the wire stabbing into the weldpool and lots of spatter.
But I would assume that the Migatronic you mention is 3-ph? not 1-ph. Some of our larger output 3-ph machines have 24 steps. I may be wrong, but I don't think that there are any 230v 1-ph 250 amp machines with any more than 12 steps available from anyone.
The reason the jump from 5mm to 8mm is to try and miss the mixed arc/globular transfer range.
Re, the torch, if your unhappy with it, you should speak to Wasp. Did they specifically say a Binzel torch or a MB 25 type. Quality wise I dont think there would be much difference as I am pretty sure they are a simerla standard made in China.
If its MB25 it should be the same size handle and take the same size consumables as the one you use at work.
of course-silly me(wheres the scratching your head smiley)
thermal arc fabricator 250 has 16 steps, esab caddy mig C200i step-less, only 200amp though not 250.
12 steps is fine, just saying.
