Rivertest
I'm about to have my MG Midget tub blasted, the guy uses Soda.
What I need to know is what are the next steps to attain a good corrosion resistant shell. Obviously I've done a bit of reading but just wanted to run things by you to see if we're in agreement.
BTW. I'm not looking for the ultimate in corrosion resistance, as the car is not gonna be used in the winter and will only go out in the rain if it gets caught out, but it has to be better than the Zeibart it had originally..!!!!
The blasting shop will apply a coat of zinc primer, Red Bonda, following the strip. I will be inspecting before they do this.
Back at home I then intend to finish some chassis repairs, I've done most of the major stuff, sill replacement etc.
Then, seal seams with polyurethane.
Underneath will then be primed, then a coat of stone chip, then topcoat and finally waxoil throughout. I'm using cellulose BTW.
Have I missed anything?
Thanks in advance for your help.
