P Paint munky Member Messages 101 Feb 26, 2012 #1 What oil should i be putting in my compressor? its a fiac belt driven if that makes a difference.
T tigler Expert on the trivial Messages 3,931 Feb 26, 2012 #2 Any good compressor oil, ISO 68 grade which is SAE20. You were correct to specify the compressor, it does affect the oil selection.
P Paint munky Member Messages 101 Feb 26, 2012 #3 So there is specific compessor oil, glad i didnt chuck the spare bike oil in it then. Where would i find such oil, machine mart???
T tigler Expert on the trivial Messages 3,931 Feb 26, 2012 #4 They do one but it's either SAE30 or 40, too heavy. I think SIP may do it and I've seen it on Ebay. Morris oils do a good one if you can find a local distributor, I'm sure if you asked Morris they would let you know the nearest.
P Paint munky Member Messages 101 Feb 27, 2012 #5 Would motorcycle fork oil do? http://www.ebay.co.uk/itm/MOTORCYCL...53?pt=UK_Motorcycle_Parts&hash=item1e6745b75d Reason i ask is this is readily available at the local bike shop
T tigler Expert on the trivial Messages 3,931 Feb 27, 2012 #6 Most probably not, it isn't intended to work at high temperatures.
