3/4 or 22 mm copper the best. less velocity of air down the pipe and a bigger cooling surface then drop off in 15mmMy shed is roughly 6 metres long ,i have a large compressor outside that i got when an uncle died, and i want to run a copper pipe the length of the shed with a few outlets off it. I was going to use 3/4" but would 1/2" do just as well ?
Don't know rated pressure, but soldered properly will be well above what you require.What pressure can the copper solder fittings handle or what pressure are they rated for does anyone know ?
