54" length of 100x50mmx5mm box or two 50x50x5mm box welded together to make 100x50x5mm box?
When I got the Harvey made wider, I got some 5mm plate folded into a U channel (76mm internal gap)
With this in place, I put the chains around the axle and used the winch to hold it all in place while I took it in for welding. What I did'nt realise is that I actually bent the U channel because I applied too much pressure.
While the Harvey stills works and I can still do a suspended lift I am thinking of starting again. But this time with 100x50mm or 2 x 50x50mm box to form the cross beam.
Cheers.
Cheers.
