why do u need a 3 way adaptor . all is u need is a pcl bayonet coupling socket on the end of a hose and short tails on your gear with plugs on
i need 3 separate leads as the plasma is at one side of the workshop so will run a lead around the wall permanent whereas blowing up tyres is done outside and dont want to keep changing the fittings over
Get two Y adaptors and plug one into the other to give 3 outlets.
How often do you have to remove the line to blow a tyre up or blow a hole out? Dual adaptor and two lines and just take the inflator off and put the blow job on. It takes two seconds. Get two Y adaptors and plug one into the other to give 3 outlets.
machine mart if your not fussed on the price otherwise trawl ebaythats what i will do as the 3 leads will be needed in separate places and i dont like leads going across the floor if possible
the plasma will be routed around the wall the blower will be hanging down from a beam and the airline will be coiled next to the door
if you could see my workshop you would understand why i want 3
ill get 2 ys and plug them together
any idea where from if he doesnt want to sell his in the end
