Christmas Jones
New Member
Hi
Could one of you help me out? I am in the market for a replacement compressor after my cheap sealey popped it clogs. This time I am planning on purchasing a machine that can keep up, as my 3HP Sealey always struggled. It will be used for the resto of an old car and other general work in a home garage, grinding, DA sanding, spraying small items and the odd small amount of shot blasting.
The machines that have court my eye are the Abac Pro A39B, Clarke SE16, Clarke SE18 or Clarke SE19. I am thinking of going for either the Clarke SE18 or SE19 as they are both 4HP and produce 18CFM, whereas the other machines are 3HP and produce 14CFM.
What I would like to know is would you buy an Abac or Clarke compressor? If you would go for the Clarke would you choose the bigger machine for the additional CFM’s? And lastly can someone give me some guidance on the different between the SE18 and SE19 and will this make any different with the running and reliability of the machine.
Thanks in advance
Thanks in advance
