markib71070
New Member
- west midlands
DRAPER 1502T turbo
this is on min setting 1 wire speed 6
When I just pull the trigger (open air), the wire feeds smoothly and correctly... but as soon as I start welding I can hear the motor pulsing, and the wire feed gets jerky. during the "jerky" part, it is nearly impossible to get a good arc going seems to bounce of hte metal and burn back....
Each time I would check the tip, etc.... and the wire would feed fine so long as I was feeding in open air... that again, if I was welding it would do the same burn back to the tip
if i turn the power setting from min to max it will weld fine on thicker metal
It is as though it isn't getting enough voltage (starving while arcing).... or something.... I haven't cracked it open yet, but I was hoping someone has experienced this and can give me some good direction.
so today 7/4/2020 i went and had a play with the welder and set everything min 1 so was on lowest setting for body panel thickness, turned speed to 0 the slowly turned the wire speed up whilst holding the gun to the metal got to between 1 and 2 and weld sounded like bacon frying as people always refer it to
question is
other welders ive used wire speed has always been around the 5-6 mark and people ive spoken to said the wire speed is a little slow @ 1-2 and should be around 5-6
???? what you guys think...ty in advance Mark
question is
