jacksparrow
thought better to be safe than sorry and ask people who actually know on here, which colour wire goes where?
If you could get a photo that is abit closer in it would help, th green and yellow should go to a teminal on the case somewhere and not to the four that are for the live/ nuetrals, i would have thought.
Cheers James
The earths MUST be connected to the actual frame. There should be an earth symbol next to a terminal screw that screws into the frame itself.
The earth must NOT be connected to the switch contacts.
but there are 2 screws into the frame, 1 marked posi, 1 marked neg, but they are exactly the same and both go into the frame
live feed bottom left neutral feed top left neutral to motor top right live to the motor bottom right , before u test though look at the contacts they are visible and u can see the bars running horizontal with contacts on the endsthought better to be safe than sorry and ask people who actually know on here, which colour wire goes where?
the conections are stamped in the metal frame to the left of the screws p and nlive feed bottom left neutral feed top left neutral to motor top right live to the motor bottom right , before u test though look at the contacts they are visible and u can see the bars running horizontal with contacts on the ends
is there no connection diagram sticker inside the top cover, else a leaflet with the unit?
live = brown neutral = blue does that clear it upsaying which colour to where would of been a bigger help
wouldn't of asked if there was
Im not a big preacher, but if you dont know the colour of the wires then perhaps you should ask someone who does, After all we are along time dead.
sorted and working now, so get off your high horse
