Not leaks (well till it'd gone way bad anyway).I run full synthetic on all my cars as far back as 1980s cars. From what I've read the claims that synthetic causes leaks etc are untrue.
I hope I don't offend, I just see this as a discussion and I'm no expert. As much as your explanation sounds good, it actually lacks the crucial bit: "it stops the oil scraper rings on the pistons from doing their job properly" because ... [explain the process that no longer works with synthetic oil].Not leaks (well till it'd gone way bad anyway).
Info I had was that the much better performance of the high-spec synthetic over the old-school, lower spe mineral oil (something to do with long-chain polymers or suchlike) is that the oil is too good for the engine design - insomuch as it stopped the oil scraper rings on the pistons from doing their job properly.
This leads to bore polishing, on to piston blow-by, loss of compression, crankcase pressurisation (and oil seal leaks) and oil consumption and carboning up of valves etc.... so you get an oily, smoky, reduced-performance engine.
When I worked for a Castrol Oils Distributor many years ago - their technical support dept aways advised you recommend the specification of oil the Mfr recommends (or Castrol equivalent) that the engine was designed to run on, and not any "better", higher-spec oil - for the above reasons.
I'd use the recommended oil and change it more frequently over up-speccing the oil personally (as I figured Castrol Boffins knew a lot more than I did!)
Old oils are c**p. Project Farm and other channels tested some of them against modern spec oils. The technology has advanced. Mobil 1 do (last time I checked) recommend fully synthetic for older cars. So does ChatGPT. If Castrol don't it could just be that they're playing safe.
I don't claim to fully get it either.I hope I don't offend, I just see this as a discussion and I'm no expert. As much as your explanation sounds good, it actually lacks the crucial bit: "it stops the oil scraper rings on the pistons from doing their job properly" because ... [explain the process that no longer works with synthetic oil].
If the oil is of the same viscosity that the engine was designed for, then what's changed from the engines perspective? The oil lasts much longer, well that's only a good thing. The oil has slightly better lubricity... maybe this could have some unexpected result, but does it? How significant is it? Does it offset the massive benefits from fully synthetic?
Don't be thinking you can start a "what oil" thread and have it end as quickly as that!Thank you all for your comments. I feel a little more relaxed about it now
