Slightly different design from my other one, this is for a member on the scottish vanners forum
Removed the valve, purged with water, then tipped it out
Marking up the lower door
Cut one edge of the door and welded each part of the hinge on
Bending and holding the gate hinge with a ratchet strap so I could tack it on. I'm using these gate hinges as I had them lying about, if I was buying new I would use proper weld on hinges
Marking the upper door
Both hinges welded on, then I cut off the carry handle, and cut out the semi circle with a jigsaw
And finally for tonight, welded the handle back on, but flush with the cylinder
