willpower1337
New Member
- Midlands, UK
Hello everyone!
I am new to the forum so firstly, Hello!
I am just trying to clarify something about the welder that I have. In the manual it says the following:
the |1 on the side of the welder says its 32.5amps max. Here is the side panel:
With these bits of information i would have thought that the welder will run on the 13a plug that was provided up to 65 amps but above that you would need to get a 32amp industrial socket to be able to handle the load. I only have just noticed this when the fuse went pop a few days ago welding thicker than normal material. My friend has interpreted it as it will run on a 13a plug but it needs to be a industrial/heavy duty 3-pin household socket.
I would just like to know which is the approach i should take? because if it needs a industrial plug (regardless of which type) I'm going to have it installed anyway. I just would like to know weather I am reading and interpreting the manual properly!
Thanks a lot in advance
All the best
Will
All the best
Will
