SplatterMaster
New Member
- Midlands, UK
Hi Folks,
Had my little yellow "Wolf MIG 140X" for a few years, always used with gas, gone through a few large reals of wire and 2 hobbyweld bottles on various hobby projects.
All was well until the gas valve broke in the torch (always on), failing to find just a replacement valve, I went to replace the whole torch assembly. I opened the welder up took a peak and decided it would be quicker to just swap the valve across inside the torches instead.
I put the covers back on, excitedly clamp the earth to a bit of scrap metal... click settings to my normal preferences for such a thickness... pull the trigger and nothing but a few feeble sparks followed by blown fuse. :-(
the torches where near identical in design, everything done up tight, the coiled wire outer liner bumped up nicely into the back of the tip.
I have pulled the covers back off and had a look for anything obvious I might have disturbed (I literally did just pull the covers off and decide narrr), but can't see anything.
internet reading pointed to shorts or blown diodes in the rectifier so I put a multimeter across the 4 paths through the rectifier (8 diodes in 4 parallel pairs), resistance the same for all 4 routes and current only allowed to flow in one direction through each so without any specs to go off seams healthy?!
what do I do next?
anyone got a link to Wolf schematics?
or general fault finding guides?
any pointer gratefully received!
what do I do next?
