I was welding a pach on a car I stopped welding for about 5mins fan is still going went to weld again and I have no wire feed at all checked that the tip was free and wire is turning in tip but no feed when you press the trigger the plug fuse is ok as the fan is working when you switch the set on and I have not run out of wire does anyone know what the problem could be is there a fuse in side
