Hood
I am obsessed.
- Carnoustie, Scotland
Not a clue, suppose it depends on who does the service.if you have to have the machine serviced every year what would the cost be for the service
I cut everything at 80ampsAre you cutting that 8mm at 80A Robin?
I intend to do a review on the Jasic Pro Cut 80 which arrived with me late this afternoon.
I hope to get a chance to get it fitted to the CNC table tomorrow but that will depend on whether the weather is good or not, if it is good then I will have to crack on with welding some Aluminium.
Some pictures of what I have so far.
The machine itself looks nice and well enough thought out.
I got a machine torch for it seeing as how it is for my plasma table. Thankfully the torch diameter is the same as the Trafimet I had on the table and that meant it fitted right into the torch brackets I had.
La torche est cependant pleine longueur, j'avais coupé mon Trafimet à ma convenance mais je ne veux pas en faire avec celle-ci vu qu'elle est sous garantie. Cela signifiait que cela allait encrasser le support du moteur de l'axe Z, donc étant donné que je suis un barsteward grossier, j'ai juste pris le disque à lamelles et j'ai apporté quelques légères modifications.
La torche efface désormais tout.
Je mettrai à jour mes réflexions sur les performances, etc. au fur et à mesure que je l'util
Hello, I purchased a Jasic 80, is it possible to have a photo of the Euro plug to see the arrangement of the pins on the machine torch please? THANKSI intend to do a review on the Jasic Pro Cut 80 which arrived with me late this afternoon.
The torch however is full length, I had cut my Trafimet down to suit but I don't wantto do with this one seeing as how it is under warranty. That meant it was going to foul the motor bracket for the Z axis so seeing as I am a rough barsteward I just took the flap disk and made some slight alterations.
The torch now clears everything.
I will update with my thoughts on performance etc as I get to use it.
I will try and remember to take a pic tomorrow.Hello, I purchased a Jasic 80, is it possible to have a photo of the Euro plug to see the arrangement of the pins on the machine torch please? THANKS
So 50% water, 10% sunlight , 5% landslide and 35% doom and gloom ?Quality Scottish air
The edges are sort of fuzzy but a light, single pass with the flap disc smooths them out.
Here is the one I did on the Jasic yesterday.
You are obviously ignorant of the weather in this part of the worldSo 50% water, 10% sunlight , 5% landslide and 35% doom and gloom ?
It was over 3 years ago that the review was posted
Sorry forgot to look, will try and remember tomorrow.Hello, I purchased a Jasic 80, is it possible to have a photo of the Euro plug to see the arrangement of the pins on the machine torch please? THANKS
Updates about the plug or?Any updates ? I'm looking for a plasma for my new table.
How is the unit performing ?Sorry forgot to look, will try and remember tomorrow.
bonjour, essaie de voir quand tu peuxDésolé, j'ai oublié de regarder, j'essaierai de m'en souvenir demain.
Des mises à jour sur la prise ou ?
Hello, try to see when you can. (Translation).bonjour, essaie de voir quand tu peux
