Arc Tourist
- Wales
Cool idea, but I would make it out of a softer metal such as brass, so not to damage the knurling on the chuck.
Or something like this? There is another type with leather strap and a heel. Which I've just decided to buy.Cool idea, but I would make it out of a softer metal such as brass, so not to damage the knurling on the chuck.
Me tooI have used stilsons in anger for the this job
We all haven't got your vise-like grip.Saw that in my feed too. Interesting idea but overengineered for the task. Defeats the object of having a keyless chuck too.
I don't agree. I've had one lock up when tapping.An Albrecht chuck doesn't need it.
Tapping with a keyless chuckI don't agree. I've had one lock up when tapping.
Cue thick rag and slip-joint Knipex with the back gear engaged.
Another "me too" here before I took the bl**dy thing off, hurled it across the workshop and resorted back to keyed chuck.Me too
Animal I wouldn't dream of doing such a thing
If only I had a 2MT collet chuck...The quickest way to muller a keyless chuck is to tap with it. In 30 years of toolmaking, the only time keyless chucks have given problems, is after some numpty has tapped with it.Use a collet chuck for tapping.
Or you buy a chinglish one that hadn't been greased and was full of grit...It was from either RDG or Chronos (not cheap)If only I had a 2MT collet chuck...
After a lifetime of nipped fingers from badly fitting keys, I haven't got a single keyed one in use. I strip the keyless chucks ,clean and molylube.If you need a vice like grip to operate it, then something is amiss.
I don't use keyless largely because I haven't got one and I haven't got one because I don't want a cheap one. If (as I suspect) you need to throw a fair bit of money at the problem (whatever the "problem" with having to use a key) then I'd probably throw the money at something else.
Moot point for me because I now have a lifetime supply of Jacobs chucks to play with thanks to @Gavlar.
