B Bornfree Member Messages 1,921 Location England Norfolk May 14, 2022 #1 I've got to re-roof a garage and iam going to use box profile steel sheets. I see they do them with an anti condensation coating on the underside. Does it work or is it a gimmick?
1 123hotchef Member Messages 14,019 Location Kent May 14, 2022 #2 you could always use a membrane first
gaz1 Member Messages 18,319 Location westyorkshire May 14, 2022 #3 it does work to a degree is it worth buying like that and having no insulation no your far better off buying normal insulation sheets or just buy normal sheets and fit insulation below it if you have the old type garage lift the roof with a light wood structure fill with insulation and use your profile sheets above it Another roofing question. keep it simple and build the frame up barge board it and fit everything on it then fill with insulation built the same way just not with large gaps www.mig-welding.co.uk
frank horton V twins are great but 4"s rule......... Messages 3,903 Location Crete, Greece May 15, 2022 #4 just get the insulated type.........not worth the time to mess about...... fit once and forget.........
