prepman
- Gwynedd UK
At the moment I'm having to make a stock Bin rack as the t'other uns collapsed/ Using ali weld skills, or lack of. Workshop is a bigger s'heap than ever.Here's an idea, here's a pic of how I repaired my Alba shaper, the part you're having trouble with broke clean of, oh what fun that was!
How about making summat simlier but incorporating a lump sticking out one side, threaded right through to take a stout threaded rod.
The threaded rod could pass through a fabricated support/thrust bearing at the back of the ram, with a wheel on the end.
Not sure how feasible this is, I'll have a look in the morning unless you beat me to it!
Just as a point of interest when I bought the shaper it had the wrong speed motor fitted a 4 pole instead of 6-8 pole if I remember correctly. Whatever it was, it was twice the speed it should have been. Couldn't source the motor so made new pulley to gear it down.
Went like a demonic sewing machine when it first arrived and tried to escape through the door.
Also main reason for purchase was to produce internal keyways Then I realised it was far more versatile than the miller for small one offs. Inexpensive tooling also. I can be finished by the time I set up the miller. But this stroke adjuster....argggh!
Your Alba is a heavier set machine than the Elliot, but very similar. He use the opposite approach to the one in the Elliot manual i.e. set in the vertical, but then no opposing force to the tightening of the adjuster nut, which is the main issue.
