- Birmingham
Had it going for about an hour, it got to 70 after about 15-20 minutes and stayed there.How long did you let it steam to reach 70c ?
Well you certainly gave it enough time to stabilize.Had it going for about an hour, it got to 70 after about 15-20 minutes and stayed there.
Unless you have so much thermal loss that the can't boiler keep up.
How about using a 2nd hand pressure cooker ?
Is that prescription or same as front line?Fipronil is the same stuff…….https://www.mifarma.co.uk/effipro-spray-500-ml?gclid=EAIaIQobChMI6d-__KfugAMVN4BQBh2d7QeeEAQYCCABEgKdrfD_BwE
Just order it on lineIs that prescription or same as front line?
I meant is it the same as the front line one or the prescription one that I would get prescribed by a vet.Just order it on line
Fiprinol is the ingredient in front line, products containing it are available with out prescription on line!I meant is it the same as the front line one or the prescription one that I would get prescribed by a vet.
Ok Cheers. I can buy front like products over the counter but I have been told the formula has now been altered and its not as good as it used to be.Fiprinol is the ingredient in front line, products containing it are available with out prescription on line!
Ok
I have yet to find out what a vet would prescribe for fleas.
Excellent....however, to get to the full 100c try lighting the bale on fire next time.....Tried the temp probe in the middle of the haynets today, it even hit 90°C at one point
It's to reduce the sugar levels in hay to help treat EMS (equine metabolic syndrome) which is similar to type 2 diabetes in humansI asked my neighbor, that used to have horses, he still makes hay.
He said the Steaming is not for sterilizing, more just for the dust.
They had horses that had the dust problems, and they just kept a spray bottle
with water, and spritz the hay just before feeding.
YMMV
Ah, I see.It's to reduce the sugar levels in hay to help treat EMS (equine metabolic syndrome) which is similar to type 2 diabetes in humans
A small animal vet will tell you to use what ever they stock that they make most money on……but you really need to know what you are actually trying* to treat first. Sometimes, mites, and allergies have similar symptoms to fleas.Ok
Weve been baling the last of our shared hay crop today, looks better than last year, should really get it tested. Few left (80) to stack to tomorrow, thankfully done for another year. Emerald green feeds do a low protein grass chop for such things I think, only about 9% protein.It's to reduce the sugar levels in hay to help treat EMS (equine metabolic syndrome) which is similar to type 2 diabetes in humans
