brightspark
- yarm stockton on tees
one of my comps has a full pressure outlet one end and the other a regulated water seperator
I once witnessed a crows foot connector come off……it wasnt good. Becareful!ah... well there goes that plan
tempted to try some pressure washer quick release fittings... might give one a test to try :-)
Compressed air is powerful stuff (or any gas under pressure). I was once at the garage at Heddon on the Wall. Guy starts blowing up golf low profile tyre. Bang…….Two squaddies and my self reacted, the-rest of the customer base looking bemused. 18 stone bloke flat on his back from the tyre blowing outdecided to give up on quick release... I'm sure in the future when I need to move something around I'll regret it
until then... it's not worth the bother
I didn't think much about restriction in quick release fittings... but then I opened the 1inch drain tap on my big air tank when it was at 150psi... - I only meant to crack it open but it was stuff and suddenly gave... I was squatting down to reach the valve, the blast of air knocked my over onto my back
If you can a regulator is a good ideal. If you can find a 1/2” one that would be my preference but I’m not sure what tools you plan on using.I'm wondering if I need a air regulator on it as well
