Screwdriver
Is that wrong then, as according to the HSE it does, or at least can, produce fumes? In fact one of the high risk activities they mention is melting and casting.
No that’s not wrong, you should of course perform any such activity outside (as I said earlier) but the danger in using lead specifically is ingesting it from physical contact. The fumes produced by any smelting process can be dangerous and toxic.
So really while smelting and therefore generating any toxic fumes should always be outside and/or well ventilated while wearing a mask etc., the particular danger with lead is that of ingestion. That’s why you need to be more careful with grinding or abrading any lead containing product because it’s the dust and fine particles that get you.
You cannot produce lead gas easily during any smelting process unless you’re welding (where you could end up with a plasma!) or otherwise heating it beyond its boiling point. I am only reacting to the notion that “lead fumes” are the danger when the reality is the specific dangers of working with lead are quite different even though the typical safety precautions should also be followed during any process which produces any sort of fume.
