D danman Member Messages 236 Aug 25, 2021 #1 Evening all Took the liner out as sticking an not good. so never done it before and yes theres the metal in an white outer plastic. where is best place to get a replacement. All new to me
Popcorn Forum Supporter Messages 1,050 Location 'ull Aug 25, 2021 #2 Curtain wire works well. available from most of the common diy outlets.
wyn Member Messages 3,596 Location Cardiff Aug 25, 2021 #3 I've changed a few on mine and got them from Rapid welding.
A a111r Member Messages 2,140 Location London Aug 25, 2021 #4 Measure the OD of the metal liner fitted. Curtain wire works well with DIY Clarkes etc, but not sure for a Kemppi. You may find that a 3m or 4m standard Euro liner is dimensionally better, so can be cut to length to fit the fixed torch.
wyn Member Messages 3,596 Location Cardiff Aug 26, 2021 #5 The ends on the kemppi and euro torch liners seem to be different.
arther dailey Member Messages 6,001 Location England Aug 26, 2021 #6 second, rapid welding, use an original on a kemppi miniarcmig because they are worth it
Munkul Jack of some trades, Master of none Messages 7,373 Location Cumbria Aug 26, 2021 #7 Aye just buy a proper Kemppi one, for the use you get out of a steel liner (should be lasting at least 100kg of wire!) MMG22 3mtr Liner Genuine Kemppi Liners for Steel and Stainless Steel and www.unitedwelding.co.uk Is this the item you need? I'd double check against the manual first just to be sure.
D danman Member Messages 236 Aug 27, 2021 #8 So, bought a kemppi from Rapid welding. Thanks everyone.
