graffian
Seer unto the end of his beard
- gatwick
I have made several over the years. I nearly always chop them up to use the metal for something else. If your after material for the clamping beam and bending leaf[thats what I call them] go into a scrap yard and persuade them to let you slice a big rsg up, well thats what I will do next time.
The last bender I made was nearly all bolted together, so it can easily be altered, and was made out of odd bits of scrap. It will bend 3mm 1 m wide, but you have to open the radius up, I folded up cross members for a range rover on it. I will probably make another to do 60 inches some time, I have never seen a proper one, I woudl liek to know how the fingers are held in place on a box pan folder? I really need to add bracing, but at the moment it has a work top fitted to it so the space isn't wasted. I have nicked the handles to use the tube for something else, I use a pair of mole wrenches as handles now;-)
You can get around the need for large clamping/folding beams by going the route the aussie people who make the magnetic clamping folder did.
They're £60.
