puffernutter
Puffernutter
- Wiltshire
Regardless of the setting, pulse, spot or continuous, I only get a short amount of wire fed before the contactor opens. Initially it will give about 250mm, but the length decreases on each trigger operation. It won't do pulse or spot either.
I suspect the circuit board? I initially thought it was the switch and replaced it, but it still does the same, so the timer that controls the wire feed? The circuit board was sent away to be looked at on 2017 and it was fine.
Any thoughts please?
Cheers
Peter
Cheers
Peter
