julianthegypsy
- Cirencester
Sorry if this should be in the ESAB section but I thought it might be a non brand specific problem. I just picked up an old one of these from a guy I know to be honest, but it hadn't be used for some time. Powered it up ok, hit the trigger, gas solenoid kicked in and feed rollers started, speed controller worked fine so I ran some wire through, hit the trigger and...nothing. No arc at all at the torch. Turned it off. Checked all the obvious connections, turned it on again and tripped the entire power supply to my unit. Had another look this evening, after landlord had restored power, turned on ok, turned off, turned on again and power tripped out again (without wire in the torch this time, just turned it on). Has anyone else had anything like this happen? If so, what did it turn out to be and how did you fix it?
Many thanks, Julian
Many thanks, Julian
