Do you want to sell itI’ve got a Kel-Arc in the shed, it’s like the old joke … tried it once & didn’t like it. Bought it about 40 years ago on a whim hoping to weld thin stuff with a arc welder, with the small migs around at a reasonable price now, there is no reason to use one.
There is a copy of the instructions in Post #18 of this thread:Hi
Does anyone know how to use and adjust a xp welder by rawlplug
Thanks
Where can I find post 18There is a copy of the instructions in Post #18 of this thread:
Anyone know what this is?
I think it is some kind of welder but im not sure what. My mate is asking and ive never seen one. Obviously i cant go and have a look due to the current situation Thankswww.mig-welding.co.uk
Still struggling, can only see up to post 9on the right hand side at the top corner of each post is the post counter so click the link and then wil find post 18 and the info you wanted
Thanks, found iton the right hand side at the top corner of each post is the post counter so click the link and then wil find post 18 and the info you wanted
Want to sell itI’ve got a Kel-Arc in the shed, it’s like the old joke … tried it once & didn’t like it. Bought it about 40 years ago on a whim hoping to weld thin stuff with a arc welder, with the small migs around at a reasonable price now, there is no reason to use one.
Can anyone tell me what transformer I should get to use with a rawlplug welder,on the right hand side at the top corner of each post is the post counter so click the link and then wil find post 18 and the info you wanted
Found it, Thanks,There is a copy of the instructions in Post #18 of this thread:
Thanks so much for the info, I will take a look,"Can you tell me what transformer I should get to use with a Rawlplug welder, and where I can buy one?"
The Rawlplug/Kel-Arc/XP welder attachment ( sorry, it cannot really be called a welder....! ) was designed to allow an Arc welder ( or a set of car batteries ) to be used for welding thin metal, by using a "buzzer" to reduce the current by intermittently breaking the arc. Now that MIG welders are available to the hobby market, it is obsolete, and only has curiosity value, as an antique.
It can be supplied by from one to three 12v car batteries. That would total 12 to 36 volts, and be capable of delivering 50 to 200 Amps, if fully-charged and in good condition. Alternatively, a mains transformer with a low voltage high current secondary can be used. I'm not sure what thickness of metal you want to try welding ( need about 30 to 40 Amps per millimetre of thickness ), but as a rough guide the transformer output would have to be about 100 Amps at about 50 volts ( and 230v AC mains input ). This is the middle of the power range specified in the Rawlplug instructions, which offer metal thickness from about 0.8mm ( thin car bodywork ) up to 6mm ( 1/4 inch ).
A transformer of that specification is usually only commercially available when it is classified as a "welder". In other words, you'd be looking for a traditional transformer-based AC Arc welder, commonly known as a "buzz box" ( because they do make a humming noise... ).
For example, here is a 48 volt 110 Amp unit from Screwfix:
This type of transformer is large and heavy ( 10 to 20 kg ) and not very popular today, so there are plenty being disposed of. Try searching for "arc welder" on Gumtree, eBay, etc., and you will probably be able to find a secondhand one on offer locally "for collection only", at around £15. They are just a transformer in a box, with almost nothing to go wrong, so even tatty rusty ones will probably still work OK.IMPAX IM-ARC140 / 10 / 115 110A Arc Welder 230V - Screwfix
Order online at Screwfix.com. Easy to use arc welder for general repair and fabrication. Accepts welding electrodes that broadly match the workpiece thickness (1.6-3.2mm). Ideal for welding mild steel and mild steel alloy. Thermal overload protection and fan cooling for improved duty cycle...www.screwfix.com
Modern electronics has made transformer-based Arc ( "MMA" ) welders obsolete. Today they are half the size of a shoebox and weigh a couple of kilos. Try searching for "ZX7-200" on eBay. E.G. :
MMA 200Amp Portable Inverter Welder Inverter Welding Machine 4000W ZX7-200 220V | eBay
Power: 4000W. High frequency inverter features quick arcing and less welding splash. Portable welding machine with carrying handle, convenient to carry. LCD display, easy to adjust current strength for welding different materials.www.ebay.co.uk
As mentioned, the Rawlplug was an early substitute for a MIG welder. Here is an example of an actual one that is cheap, works OK, and is both a MIG welder and an Arc welder :
Professional 140A Gasless MIG, TIG and MMA 3-in-1 Welder Non Live Torch model 230V No Gas with Mask & Welding Wire
This model has 3 functions, working as MIG, TIG and MMA welding PRODUCT NAME; * 140 Welder 140A With Accessories. For greater welding control the wire is only live when trigger is used Cheaper models have permanent live feed wire making it difficult to set the wire in the correct starting...dirtyprotools.co.uk
So are you saying that if I can find a cheap arc welder I can use this to connect to my welders mate rawlplug welder, if so is it a case of connecting the positive of the arc welder to the positive of the rawlplug welder and the negative the the work piece, sorry but I really would like to use my rawlplug old welder,Thanks so much for the info, I will take a look,
Would this item be OK EddieSo are you saying that if I can find a cheap arc welder I can use this to connect to my welders mate rawlplug welder, if so is it a case of connecting the positive of the arc welder to the positive of the rawlplug welder and the negative the the work piece, sorry but I really would like to use my rawlplug old welder,
Thankyou again
Adjustable volt output, but can't see what amp outputWould this item be OK Eddie
NDK-150VA Chint 150VA Control Circuit Transformer
Chint have a global supply network with branched and regional offices in the USA, Middle East, Germany, Russia, Brazil, Ukraine, Hong Kong, and Great Britain. As you can imagine their product range is vast which includes MCB’S, RCBO’S, Contactors, Distribution Boards, Home consumer units, Motor...www.ledcontrols.co.uk
