GavJ
- Glasgow Scotland
Anyone using one of these with gasless wire...... I cant get mine to lay decent runs. I suspect its not powerful enough for what Im doing. Most of my work is 3mm thick medium quality tube, I can get a fairly contious bead using 0.9mm wire and set on high & wire speed around 5 and a bit, but getting no penetration. The bead just sits on the surface....... its sticking the pieces together but with very little melting of the parent material.
If my assumption is correct where should I go? Looking for a mig, gas or gasless that runs on a 13amp plug that can do 3-4mm plate & tube.
