Brad93
- Essex, United Kingdom
Did you do these individually? How did make sure the ends aren't flat?A pile of segments rolled for @grim_d .View attachment 331630
Or did you roll over length then cut down
Should have sent it to me. I already have an EDM diesinker electrode that I made for 1/2” drive sockets !Yep, hard work in en24t.
Didn't think of it.
Becoming tedious parking the digger,then walking back to gather tools,so I made a rack.
I’ll add it to the next galvanising trip.View attachment 331462View attachment 331463
Rolled 1m bars,then cut.Did you do these individually? How did make sure the ends aren't flat?
I was intending to try brass tomorow. I want to see what this can do incase it fails, I'll know what needs to be redesigned. Power is no problem, unsure about the element life and how well it is retained.When you've perfected casting brass I'll have a commission for you. Hopefully I'll be able to supply a suitable mould...
I have about 5kg of old taps and fittings, old gas regulator and about 1kg of swarf. The taps were chromed which may be a problem, would I be left with a chrome /nickel shell to fish out, or would it disolve into the melt?What are you intending using, plumbing fittings?
I doubt I can achive that level of detail but would be interesting to try. The picture would suit electro growing if you start with a negative 3d print?
Welded together to make them identical using a grinder.
Another mini excavator bucket in production
This time I'm completely fabricating it from zero.
Cut the sides from 6mm sheet using the plasma cutter .
This evening hopefully I'll have ground them up and bent the bottom plate .
It's a small 5 or 6" bucket i still have to know the width of it.
Quick change from the shelf.
That's a good trick. Any pictures of you doing this?
It's for work .Is this for work or your own job?
It was a joke. The sentence reads somewhat differently to your intentionNope unfortunately there's no time to make photos.
Well , I've dreamed for years and years to work in this sector .It was a joke. The sentence reads somewhat differently to your intention
