Sergei Slovenija
- Slovenija Ljubljana
Installed the sleeve onto the shaft using an anaerobic fixative. The other day, finishing grooving and polishing of the bronze. I'll fill the groove with epoxy. The original sleeve can probably be removed by annealing the rubber without fanaticism (it has a rubber layer!). So as not to spoil the original varnish of the crosspiece.
I wonder, could they be used to dull down/ alter the resonance of a ringing anvil ?Started grinding the pitting down on an old anvil stake.
Realised the two big rust dimples were actually holes filled with lead.
Stared in confusion.
I like your design. As I've posted elsewhere on the forum, I've been thinking about ways to store my 'flat abrasive' stuff. Due to lack of space in my shop, I'd have to either hang it under a shelf or under a workbench.Nothing fancy, just a rather rough-and-ready rack for storing sanding stuff.
I think my definition of rough and ready is a bit different to yours! – that looks really good, as everNothing fancy, just a rather rough-and-ready rack
There's a reason the labels cover (aka hide) the ends of the grooves that the shelves sit in.I think my definition of rough and ready is a bit different to yours! – that looks really good, as ever
Quick and dirty ECU for the 6x6 engine. Once it's up and running I'll replace the off the shelf module with a custom one.
Diy efi - I think I've got one of them here somewhere, never got around to building it up.
I actually have bought one a year or so ago.It'll be interesting to hear how you go with this, I've considered adding Speeduino to one of my Vauxhalls but not done anything about it.
I feel the same some days with my tig welds.Earlier I knocked up a mounting for my Webasto diesel heater. Where (I think) I'm installing it in the van I need to go through 12mm lly and another 25mm of insulation & batten before getting to the floor pan - so I thought I'd make an ovalled "tunnel" mount so the heater body will stand proud of the insulated floor rather than me cut a huge chunk of it out.
I had a piece of stainless steel offcut left from the galley kitchen splashback. I don't have stainless wire in my MiG, but I thought I'd have a lash with it anyway - as I've never tried welding anything stainless before.
I've not welded for months, & I'm self-taught and not many torch hours.... so frankly my welds looked ropey as hell - pretty horrible to look at, but solid.
It was a nice change to play with the dinky Rollers, the metal shears/guillotine, the 6x4 saw & the mig welder. Need to cut some threads on some long & shouldered M6 bolts I've ket from something tomorrow am (I've cut the bolt heads off ready, as I need longer threads now from the heater baseplate to mount it).
(No pics, as the welding is too fugly!)
It's not just underlined - I think you've linked to the whole Forum!Sat on my butt and changed the on off switch & emergency stop button on an old lathe . Funny how the Men's Shed " experts " reckoned six weeks ago that it was the capacitor on the motor Even after I showed them that holding the ON button in caused the motor to turn as all speeds
Several so called saved from dead equipment switches were furnished & used by the "experts " , not one worked . Still , "All's well that ends well " , the lathe is now up & running . so is the super duper double cyclone dust & shavings extraction rig I set up . It needs tidying up but it works in principle .. all I need to do is educate guys to use the blinking thing when they use the machines it is designed for .
Oh Ardy , I really feel for you when the Norberts turn up at your sheds in multiples of three or more .
PS.
Don't know why the puter has decided to underline everything
Most electricians have no clue how a motor or the associated control gear actually operates so i'm not surprised.Sat on my butt and changed the on off switch & emergency stop button on an old lathe . Funny how the Men's Shed " experts " reckoned six weeks ago that it was the capacitor on the motor Even after I showed them that holding the ON button in caused the motor to turn as all speeds
PS.
