angellonewolf
- bristol england
yes agree electrics vary what seams to be by quite a lot with having a quzz arc that went up to 200 amp would weld 3.2 rod easy on a 13 amp plug was not doing for long at 115amp
and the sureweld i had would only run a 1.6 rod or would blow a fuse at 80 amps so they do differer largely
but as above untill the trigger is pulled there would only be some amps going through not a large amount to pop a mcb does the transformer not come in till the trigger pulled ?
