That would be ample if you can get it spinning at the required speed. The impeller could be mounted in a large tube to increase chances of 'capturing' the flow and a belt drive to the generator which is up out of the water. The tube would help because, as brightspark says, the water will take the easiest path so when there is a load on the genny and the blades are harder to turn the water will just flow around as much as possible which is harder to do if it is 'channelled'.
Bear in mind that if you used 2.5mm cable from your river to your batteries you would lose about 5 volts across the cables while drawing only 1 amp.
i don't know your exact situation but also worth thinking about floods where your genny/running gear could get a proper soaking and protecting against floating debris.
What kind of solar setup have you tried? How many watts etc.?
