the snooper
getting older by the day
- Hull UK
Isn't what you are planning illegal in the UK
It may well be but he isn't in the UK.Isn't what you are planning illegal in the UK
I'm afraid I don't know anything about the new kit so I can't commentI wasn’t sure about the new stuff as modern artics seem to be pushing for less axles and tyres all the time so you would assume the suspension pressure would increase?
I have part of a discovery air suspension system recycled and used as air assisters on a leaf sprung vehicleRange Rover air suspension good luck fixing that, heard so many tales of woe even from people with lots of experience of them
The usual issues with Land Rover air suspension is people not replacing bags when they need replacing, then the compressor goes then someone tells them it will be a really good idea to put coils in.
P38 suspension isn't best but it's not that complicated and you can buy o ring kits for valve blocks.
Personally I'd be surprised if you get enough inrush speed to hop a Range Rover, the other thing to remember is the air bag on them has the shock strut going through the middle so those bags listed just won't work without a redesign of the suspension unless of course you don't plan on driving it.
There are far more things to be concerned about on a P38 than it's air suspension but they are a great car to drive. I had 4.6HSE and it would do 18mpg even ragging it.
The ones that jump really high run hydraulics and even those will often burn out a pump after a few goes because they are running them way harder than they were designed to do. The Cutlass seems to be the go to car for that jumping scene
Airbags are separate to shocks on p38s. I think later l322/l302 have combined shock and spring.
